OSPF PTP link showing 0 Neighbors
I am trying to change over a link between two routers form NBMA to PTP as the link is handled by a PTP radio.
when I change the Network type on each router to PTP, both show 1 neighbor for a few seconds then one goes to showing 0 neighbours.
Routers are a 3011 at 10.10.8.249 and a hEX POE at 10.10.8.252 - .250 and .251 are the radio interfaces and the subnet is a /29 - is there anything from the attached screenshots I’m doing wrong.
screenshots: https://imgur.com/a/qZ0oxZ2
Yes, posting stupid screenshots instead of config. exports.
There is no need to be rude.
Hey. Can you show a neighbors table and network/area config?
Have you figured out anything with this? I am having kind of a similar issue. OSPF doing Point to Point. Happens sometimes after a reboot. One router will show 1 neighbor and 0 adjacent neighbors and the other router won’t show any neighbors at all. I really need to find a fix for this. Just hoping you had figured something out.
