Ospf restart
Hi
I changed Ospf cost of one line to change
routing. But this is only working after a reboot :frowning:
(you need a cisco to verfy this as you cant see
the summed up costs in ros)
Any other method to restart ospf fast?
Using: 2.9 46 routing-test
Stefan
There are 3 todos hidden in this message. If
mt finds them they are allowed to do them :wink:
I think MT is not looking for hidden messages, it is making ROS better =)
try in script disabling and then enabling of OSPF networks - it seems like it restarts OSPF
I notice you are using the routing-test package for OSPF.
I have been using the routing package (not test) in same version for OSPF.
I have not been doing this long, I’m sure you probably have more experience with ROS and OSPF. Is there a reason I should switch to routing-test or a reason I should leave it alone.
I don’t want to fix it if it isn’t broken, but if I can avoid it being broken by using routing-test then thats good :slight_smile:
Scott
yes but lt is never fast enough :wink:
I try this. ThanX
Stefan
routing-test is newer. test does not mean its buggier.
But if routing works for you …
Stefan
