OSPF Resting without reboot
Does anyone know if in 2.9.12 there is a way to reset OSPF. Like turning off and on the service.
Sometimes it seems the only way to get OSPF to start working is to reboot the router.
If not, I will like to ask Mikrotik to add this feature in a future release
thanks
-Carlo
Disabling everything in “/routing ospf network”, and then re-enabling it usually works.
–Eric
Running v2.9.23 with OSPF. Several times on many different routers, if one of the routers gets power cycled without a reboot command, the OSPF routes will not communicate with other routers until we remove the network and then re-add it on that router.
This was a problem a year ago, and obviously is still not fixed. When will this be fixed? This is a MAJOR problem that needs addressed ASAP.
Have you guys tried routing-test? It fixed the not communicating problems I was having(getting stuck in Init)..
-Gerard
I thought routing-test was the “default” package now with the Routerboard installs?
However, I see a routing-test for the non-routerboard installations.
So, is the RB install using the routing-test and the others are not?
