OSPF ROS v7.[567] IPv6 example?
I have search high and low and was unable to find an example of OSPF setup for ROS7 for IPv6
I have two routers (soon to be more) one CHR and one 5009 connected via a GRE tunnel which are currently running fine and distributing IPv4 routes just as expected. Since we are running fully dual stack I am now trying to add the IPv6 network to get rid of the ugly static routes.
Is there anywhere a working example of such a dual stack setup ? All I can find is simple IPv4 single stack.
Add another instance for ipv6
if that would only work so easily, I would not have asked. That is what I was trying for the last couple of days off and on.
Maybe as a complication, not sure if that has any impact, the interface OSPF is running on is a GRE tunnel And I am thinking of moving to a VXLAN.
Thus far IPv4 works as a charm, IPv6 is illusive
Should be pretty easy, something like this:
/routing ospf instance
add disabled=no name=i4
add disabled=no name=i6 version=3
/routing ospf area
add disabled=no instance=i4 name=bb
add disabled=no instance=i6 name=bb3
/routing ospf interface-template
add area=bb networks="1.2.3.0/24"
add area=bb3 interfaces=ether1
Thank you very much, the difference in setup with the interface= clause made all the difference.
Works now
