Did you check your ospf instance if out-filter was set?
[admin@MikroTik] > routing/ospf/instance/print
Flags: X - disabled, I - inactive
0 name="ospf-instance-1" version=2 vrf=vrf1 router-id=10.0.0.1 out-filter-chain=ospf-out
1 name="ospf-instance-2" version=2 vrf=vrf2 router-id=10.0.0.2 out-filter-chain=ospf-out
[admin@MikroTik] > /routing/filter/rule/print
0 chain=ospf-out rule="reject"
[admin@MikroTik] >
it should reject everything try that first otherwise this is a big pita, routing filter is not working on VRF hahaha
ospf-in is working but not ospf-out
ptsch
July 1, 2025, 8:32pm
23
yes it is. doing print shows the out-filter
ptsch
24
i can’t get either one to work
In winbox it was filtered in CLI 192.168.3.0/24 is not listed
I made support ticket on this and let see what will happen
ptsch
July 1, 2025, 9:09pm
26
thanks! keep us posted. hopefully the latvians didn’t gain independence sometime in early july
I think with this EVPN + VXLAN endeavor they have all of this VRF related issues will going to fix eventually the only question is the timing when? hehehe
I need a very elaborate scenario to convince support that this was indeed a bug, my mistake was the example I sent to support is from a directly connected routes, this time i’m going to try to block a prefix learned from another routing protocol to make a convincing argument.
# MT Support
You should check the documentation on what OSPF output can filter. As far as I can see there is not a single LSA in the list that is eligible of being filtered.
I see this post, Kevin was right
Trying to get an idea of the “official” MikroTik answer here. As far as I can tell, unless you’re redistributing connected, rip, bgp, static, etc , it’s not possible to filter routes for LSA types that aren’t external
In ROSv6 the official answer to filtering routes outbound for an LSDB within the same area was “not possible” unless they are external routes.
http://forum.mikrotik.com/t/ospf-out-filter-not-working/12082/1
In ROSv7 i’ve come across a few posts that claim it’s possible but I’ve …
On R2 ospf-out successfully reject the prefix learn from R3 by means of redistributing BGP routes learn from R4 into ospf domain
I’m going to close the ticket with Support, it’s user error
On R3 100.65.0.0/24 was install in the RIB
On R2 100.65.0.0/24 is not present because ospf-out filters is in effect
