OSPF routes does not come out on routing table
My router successfully made adjacency with my other neighbor using ospf, I can see the LSA updates in the LSA tab but there is no route for the ospf came out on my IP route. This was working when I was using v6. Btw I am using RB5009 for this. Any ideas?
Turns out I need to correctly state network type for each template. I have a l2tp ipsec connection and I need to set it as ptp network instead of broadcast, then the routes appear in the main routing table. This has no issue in v6 version as it will auto configure what type of links you are connecting to through OSPF.
