OSPF setup
Hello everyone,
This is my current setup. I recently installed RB450 at Tower 2 and its running in bridge mode.
How do I setup OSPF in my case?
Sent from my SAMSUNG-SM-G935A using Tapatalk
You need to supply more information, like IP assignments etc.
Case studies here should give you a starting point.
https://wiki.mikrotik.com/wiki/Manual:OSPF_Case_Studies
@Rudios I have not setup any IP’s or areas.
Ether 2: x.x.x.218 (WAN IP)
Ether 3: x.x.x.10 (PPOE server)
Ether 4: connected to switch (users connected to switch)
How do I start?
I have tried using these
http://wiki.mikrotik.com/wiki/Manual:OSPF-examples
But on my tower 2 router I see a neighbor but won’t see neighbor on my core router.
Can you ping the CCR LAN facing interface from your Tower2 RTR?
Is that network part or your OSPF config on both routers?
https://wiki.mikrotik.com/wiki/Manual:OSPF-examples
Go back through the example for Simple OSPF Configuration and replicate it using R1 and R2.
After doing that make sure you go through the log on both routers.
Yes I can ping the CCR LAN facing interface from Tower2 RTR.
Help me understand with the above example.
R1 - ether 2 where is this connected to?
R1 - ether 3 where is this connected to?
R2 - ether 1 where is this connected to?
R2 - ether 3 where is this connected to?
are the lan ports connected to the switch and ptp links in the same lan as the lan ports of the AP’s. can you share a bit more information about you setup. We understand your router lan connects to the switch but need to know further information so we can give you an example.
Here is my setup:
Office
Router A:
Ether 1 - wan
Ether 3 - IMS(radius/billing etc)
Ether 4 - Switch X
Router A is my PPoE server
Customers connected to Switch X
Now to connect to my second tower I have already established a link from office to Tower 2. Everything is fine with the link and I have installed a RB450 here.
Now the PTP in the office is connected to the Switch X
Tower 2:
Router B
Ether 1 - PTP
Ether 2, 3,4 are currently bridged where the AP’s are connected
Hope this helps.
Can I run OSPF on the same PPoE router?
Can you post export for both routers?
As in?
Simply type export in a terminal window.
https://wiki.mikrotik.com/wiki/Manual:Configuration_Management#Exporting_Configuration
/export
Ok will.
Can you tell me if I can run OSPF on the same router as the PPoE server?
That is what I am trying to do.
R1 - PPoE server
R2 - TOWER 2
Yes you can run pay on same router.
Router 2:
add name=bridge1
add name=loopback
set [ find default-name=ether2 ] name=ether2-master
/ip neighbor discovery
set ether1 discover=no
/routing ospf instance
set [ find default=yes ] redistribute-connected=as-type-1
redistribute-other-ospf=as-type-1 redistribute-static=as-type-1 router-id=
2.2.2.2
add bridge=bridge1 interface=ether2-master
add address=192.168.88.1/24 comment=defconf interface=ether2-master network=
192.168.88.0
add address=2.2.2.2 interface=loopback network=2.2.2.2
add address=10.10.10.2/30 interface=ether1 network=10.10.10.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
/ip firewall address-list
add address=10.10.1.4/30 list=ALLOW
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept established,related”
in/out-interface matcher not possible when interface (ether1) is slave - use mas
er instead (bridge1)
add action=drop chain=input comment=“defconf: drop all from WAN” in-interface=
ether1
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
add action=accept chain=forward comment=“defconf: accept established,related”
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=
invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment=“defconf: masquerade” out-interface=
ether1
/ip traffic-flow
set cache-entries=128k enabled=yes
/routing ospf interface
add interface=ether1 network-type=point-to-point
/routing ospf network
add area=backbone network=10.10.10.0/30
/system routerboard settings
set protected-routerboot=disabled
/tool mac-server
add interface=ether2-master
/tool mac-server mac-winbox
Main router 1:
add name=loopback
set [ find default-name=ether3 ] name=ether3
set [ find default-name=ether4 ] name=ether4
set [ find default-name=ether1 ] comment=wan name=WAN-ether1
set [ find default-name=ether5 ] name=ether5
set [ find default-name=ether6 ] name=ether6
set [ find default-name=ether7 ] disabled=yes
set WAN-ether1 comment=wan
add name=dynamic ranges=172.20.1.1-172.20.1.254
/ppp profile
set 0 change-tcp-mss=no dns-server=8.8.8.8,4.2.2.2 local-address=103.231.218.218 only-one=no remote-address=dynamic
set [ find default=yes ] redistribute-connected=as-type-1 redistribute-other-ospf=as-type-1 redistribute-static=as-type-1 router-id=1.1.1.1
/snmp community
add addresses=0.0.0.0/0 name=Margao
/interface bridge settings
set use-ip-firewall=yes
/interface pppoe-server server
add authentication=pap disabled=no interface=UBNT-ether4 keepalive-timeout=300 max-mru=1492 max-mtu=1492 one-session-per-host=yes service-name=alegra
add authentication=pap disabled=no interface=UBNT-ether4 keepalive-timeout=30 max-mru=1492 max-mtu=1492 one-session-per-host=yes
add address=103.231.218.218/30 interface=WAN-ether1 network=103.231.218.216
add address=10.1.0.1/24 disabled=yes interface=ether5-vcb network=10.1.0.0
add address=103.237.56.9/30 interface=SYNEFO-ether3 network=103.237.56.8
add address=103.237.56.13/30 disabled=yes interface=MSG-ether2 network=103.237.56.12
add address=172.30.21.1/30 interface=ether5-vcb network=172.30.21.0
add address=45.123.1.41/29 disabled=yes interface=UBNT-ether4 network=45.123.1.40
add address=192.168.10.5/24 interface=ether6-tata network=192.168.10.0
add address=1.1.1.1 interface=loopback network=1.1.1.1
add address=10.10.10.1/30 interface=UBNT-ether4 network=10.10.10.0
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add address=10.0.0.0/16 list=ALLOW
add address=103.237.56.8/29 list=ALLOW
add address=172.17.1.0/24 list=ALLOW
add address=45.123.1.40/29 list=ALLOW
add address=172.17.1.0/24 list=NAT
add address=10.0.0.0/16 list=DeactiveUser
add address=172.20.1.0/24 list=NAT
add address=172.20.1.0/24 list=ALLOW
add address=172.16.1.0/24 list=ALLOW
add address=172.16.1.0/24 list=NAT
add address=172.30.21.0/30 list=ALLOW
add address=172.30.21.0/30 list=NAT
add address=192.168.2.0/24 list=NAT
add address=192.168.2.0/24 list=ALLOW
add action=accept chain=input comment=“Allow Established connections” connection-state=established
add action=jump chain=forward jump-target=icmp protocol=icmp
add action=drop chain=icmp comment=“echo reply” icmp-options=0:0 protocol=icmp
add action=accept chain=icmp comment=“net unreachable” icmp-options=3:0 protocol=icmp
add action=accept chain=icmp comment=“host unreachable” icmp-options=3:1 protocol=icmp
add action=accept chain=icmp comment=“host unreachable fragmentation required” icmp-options=3:4 protocol=icmp
add action=accept chain=icmp comment=“allow source quench” icmp-options=4:0 protocol=icmp
add action=drop chain=icmp comment=“allow echo request” icmp-options=8:0 protocol=icmp
add action=accept chain=icmp comment=“allow time exceed” icmp-options=11:0 protocol=icmp
add action=accept chain=icmp icmp-options=12:0 protocol=icmp
add action=drop chain=icmp comment=“deny all other types” disabled=yes
add action=accept chain=input comment=“Allow ICMP” protocol=icmp
add action=accept chain=input in-interface=!WAN-ether1 src-address=172.30.21.0/30
add action=accept chain=input comment=“WinBox IP address Login” disabled=yes dst-port=8291 protocol=tcp
add action=accept chain=input comment=“Synnefo API Port” dst-port=8728 protocol=tcp
add action=accept chain=input comment=“Synnefo Authentication & Auditing Port - 2” dst-port=1813 protocol=udp
add action=accept chain=input comment=“Synnefo Authentication & Auditing Port - 1” dst-port=1812 protocol=tcp
add action=accept chain=input comment=“Synnefo Authentication & Auditing Port - 1” dst-port=1812 protocol=udp
add action=accept chain=input comment=“Synnefo Authentication & Auditing Port - 2” dst-port=1813 protocol=tcp
add action=accept chain=input comment=“Synnefo Authentication & Auditing Port - 3” dst-port=3799 protocol=tcp
add action=accept chain=input comment=“Synnefo Authentication & Auditing Port - 3” dst-port=3799 protocol=udp
add action=drop chain=input comment=“Drop Invalid connections” connection-state=invalid
add action=drop chain=input comment=“Drop everything else”
add action=drop chain=input comment=“drop ftp brute forcers” dst-port=21 protocol=tcp src-address-list=ftp_blacklist
add action=accept chain=output content=“530 Login incorrect” dst-limit=1/1m,9,dst-address/1m protocol=tcp
add action=add-dst-to-address-list address-list=ftp_blacklist address-list-timeout=3h chain=output content=“530 Login incorrect” protocol=tcp
add action=drop chain=input comment=“drop ssh brute forcers” dst-port=22 protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist address-list-timeout=1w3d chain=input connection-state=new dst-port=22 protocol=tcp
src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 address-list-timeout=1m chain=input connection-state=new dst-port=22 protocol=tcp
src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=1m chain=input connection-state=new dst-port=22 protocol=tcp
src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 address-list-timeout=1m chain=input connection-state=new dst-port=22 protocol=tcp
add action=drop chain=forward comment=1434 dst-port=1434 protocol=udp
add action=drop chain=forward comment=1434 dst-port=1434 protocol=tcp
add action=drop chain=forward comment=135 dst-port=135 protocol=udp
add action=drop chain=forward comment=135 dst-port=135 protocol=tcp
add action=drop chain=forward comment=136 dst-port=136 protocol=udp
add action=drop chain=forward comment=136 dst-port=136 protocol=tcp
add action=drop chain=forward comment=137 dst-port=137 protocol=udp
add action=drop chain=forward comment=137 dst-port=137 protocol=tcp
add action=drop chain=forward comment=138 dst-port=138 protocol=udp
add action=drop chain=forward comment=138 dst-port=138 protocol=tcp
add action=drop chain=forward comment=139 dst-port=139 protocol=udp
add action=drop chain=forward comment=139 dst-port=139 protocol=tcp
add action=drop chain=forward comment=444 dst-port=444 protocol=udp
add action=drop chain=forward comment=444 dst-port=444 protocol=tcp
add action=drop chain=forward comment=445 dst-port=445 protocol=udp
add action=drop chain=forward comment=445 dst-port=445 protocol=tcp
add action=drop chain=forward comment=DROP dst-address-list=DROP
add action=drop chain=forward comment=DROP src-address-list=DROP
add action=accept chain=forward comment=ALLOW dst-address-list=ALLOW
add action=accept chain=forward comment=ALLOW src-address-list=ALLOW
add action=drop chain=forward comment=“DEFAULT POLICY”
add check-gateway=ping distance=1 gateway=172.30.21.2 routing-mark=vcbox
add distance=3 gateway=192.168.10.1 routing-mark=LAN1ToWAN2
add distance=1 gateway=103.231.218.217
add distance=1 dst-address=103.237.56.8/29 gateway=loopback pref-src=103.237.56.9
/ip service
set www disabled=yes
/ip traffic-flow
set cache-entries=4M enabled=yes interfaces=WAN-ether1,UBNT-ether4
/ppp aaa
set interim-update=3m use-radius=yes
/radius
add address=103.237.56.10 comment=“added by synnefo on 2017-01-24 03:25:29” secret=
***** service=ppp,login,hotspot
/radius incoming
set accept=yes
add interface=UBNT-ether4 network-type=point-to-point
My perfect working OSPF setup stoped working after upgrade to 6.38.3.
I dont see your network under
you need to add the networks to the area in order for ospf to work.
He has network just for link. Look at the last line.
