OSPF summarize externals
Using 2.9rc7, is it possible to configure RouterOS to export a summary LSA for external
(static, connected) routes?
I’d like to advertise a pool of IP addresses that is used for incoming PPTP connections into
OSPF, but I don’t want every single PPTP session to be advertised as one host route but
would like to inject only one summary LSA for the entire pool. That would also cut down on
the number of link-state updates, as a connect or disconnect of a PPTP user would not
change the link-state database beyond the MT router…
I can not find any way to configure summary routes for OSPF in 2.9rc7. Is this supported at all?
–Tom
Well, i dont know if rc7’s OSPF filters outbound routes, but is it possible to add the network using a network statement and then filter all remaining with a route filter?
Are you using routing-test or regular routing package?
