Yes, Cisco does - I haven’t played with this myself because my IOS image that I use in GNS3 doesn’t support this - BUT, I read their whitepaper on the subject, and honestly, I don’t see any difference in running OSPFv3 with an IPv4 address family designation than just running OSPFv2 for IPv4… because even using OSPFv3 for both protocols, you must still run each one in separate process instances anyway.
It makes sense because if you use a single database to represent both protocols, then you must guarantee that your dual-stack configuration is completely identical throughout the topology because routing decisions are made based on path cost alone. If there is even one link in that path which isn’t dual-stacked, then a forwarding decision for IPv4 would be incorrect if it were based on the cost of a v6-only link, and vice-versa.
Okay, so having said all of that, my current position is that I don’t understand the internal differences between v2 and v3 well enough to understand why there would be a benefit to running OSPFv3 as a dedicated process for IPv4 routing vs running OSPFv2 as a dedicated process.
What advantages does OSPFv3 offer in routing capabilities that would cause one to choose it over OSPFv2 for their IPv4 routing needs?
Then my next question - are these advantages to adding IPv4 address family support to OSPFv3 in ROS so great that they outweigh the importance of implementing some very basic things you can’t even do in ROS at all with IPv6?
My candidates for IPv6 triage in ROS are:
ability to specify the link-local addresses of interfaces manually
ability to specify which subnet of an IPv6 address pool gets assigned to which interface when using “from-pool=yes”
ability to at least learn a default GW link-local address via SLAAC (I’ve thought of several ways this could be useful even without NAT66 being required)
ability to specify the IPv6 DNS resolver addresses to announce in RA messages to LAN clients
