OSPF version / routing package question
I am currently running ospf on ros2.9.46 with routing package mostly on rb532’s and things are fine. I have a fairly simple single-AS backbone area so far.
My first rule is don’t fix it if it isn’t broke - but I have not done near the testing and loading of many on here that use ospf on ros so I hoping to avoid any future issues I may not be aware of at this time. So having said this, which ros / routing package would I be best off with?
I am about to integrate some rb333’s into the mix but from testing they seem to play nicely with the rest of the routers I have running…
Thanks in advance…
Scott
Well with RB333 you don’t have any choice - they are RouterOS v3.0 ONLY…
So welcome to the 3.0 club :slight_smile:
P.S. OSPF is working without any problems for me.
