hello everyone, I have to build a ring video surveillance system, I was thinking of doing it using CRS112-8P switches using OSPF.
Beyond the accessibility of all switches via OSPF, in each single switch, do I insert the cameras in a bridge with only the ports dedicated to them? or do I create a bridge with one of the two interfaces that I use as OSPF inside?
Another question, since there will be a router to which internet connection will arrive, how do I give internet with OSPF to each group of cameras on a single switch?? do i need to nat all switches??
I enclose a diagram of how I planned to develop the network. However, I specify that it is not possible to create the entire ring network, but only the segment drawn in the diagram itself Copia di raffaele.drawio.pdf (32.8 KB)
then I proceed with OSPF. The only thing that will happen is that the cameras will have different IP class on each single switch. In the afternoon, I posted a diagram with the addresses. so tell me what you think
but as I wrote, I could use the CRS as simple switches. Instead in the CCR I set the bridge with a backup port that I will connect to the return of the closed loop of the switches, without using routing right?
