For client management there is a VLAN on the AP Wlan interface, DHCP server is using this VLAN, on the client CPE the DHCP client is using this VLAN to assign management
IP , OSPF on the AP has in routing/ospf/network a /24 and ospf/interface has a static entry with network type=broadcast,
I didn’t setup this configuration and tyring to understand if OSPF network type should be set to different type ( point-to-point,nbma,default…)?
or put another way is there a “best practice” configuration for a CPE that doesn’t use routing setting but AP is using ospf?
