I have run into an odd situation. I have a primary VPN server (RB1100) that is connected using L2TP to one of several VPN clients. The L2TP tunnel interface is part of an 'inside' VRF.
I cannot get redistribution of connected or static routes to function. the only way a connected route shows up is if I add it to the OSPF network list. Using the redistribute connected feature results in the route momentarily appearing in the OSPF route tab on the far end with a cost of 'infinity'. All redistribute metrics on both ends have been given a cost of 20.
I am not running BGP or MPLS on these systems as neither should be needed. I have a static route defined within the VRF-SdnInside VRF for 172.25.11.0/24 via 172.25.10.5. It appears in the OSPF ROUTES on the local machine with a cost of 20 and a tag of imported type 1.
If anyone spots something I missed please let me know... I've looked at this for so long that I will likely never see the problem!
Tim McKee
OSPF config from Server:
/routing ospf instance
set default disabled=no distribute-default=never in-filter=ospf-in metric-bgp=auto metric-connected=20
metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0
add disabled=no distribute-default=never in-filter=ospf-in metric-bgp=20 metric-connected=20 metric-default=1
metric-other-ospf=20 metric-rip=20 metric-static=20 name=ospf-Inside out-filter=ospf-out
redistribute-static=no router-id=172.25.1.1 routing-table=VRF-SdnInside
/routing ospf area
set backbone area-id=0.0.0.0 disabled=no instance=default name=backbone type=default
add area-id=0.0.0.0 disabled=no instance=ospf-Inside name=Inside-bbone type=default
/routing ospf network
add area=Inside-bbone disabled=no network=172.25.255.0/24
add area=Inside-bbone disabled=no network=172.25.1.0/24
OSPF Config from Client:
ospf-out redistribute-bgp=no redistribute-connected=as-type-2 redistribute
redistribute-rip=no redistribute-static=as-type-2 router-id=0.0.0.0
metric-default=1 metric-other-ospf=20 metric-rip=20 metric-static=20 name=
ospf-out redistribute-bgp=no redistribute-connected=no redistribute-other-
redistribute-static=as-type-1 router-id=172.25.10.254 routing-table=VRF-Sd
/routing ospf area
add area=Inside-bbone disabled=no network=172.25.10.0/24
