My problem:
When Link3 or Link4 goes down there is no change in routing table of R1.
VRRP works fine.
When Link1 or Link2 goes down all is ok.
Seems to me R2 and R3 don’t send updates to R1.
Can anybody help me?
According to another posting i found here is what they said:
First of all you must use routing-test package!
each PPPoE server must be ABR (in separate Area)
Then go to the “/routing ospf area range” and specify summary network with option “advertise=yes” then this area will distribute only summary route and get rid of all specific routes that applies under that summary route
If you would like not to advertise some specific routes you should use option “advertise=no”
