OSPF with 5.6 5.7 5.8 ... Database description
strange Problem with all 5 ROS.
On many Routerboard 411AH the OSPF hangs the Router up.
Router has /tool profile 80-90% CPU use for routing and then the OSPF goes down…
Only a reboot of the Router fix the Problem.
The Problem comes when other Routes in Network recalculate or flapped but obviously only in greater OSPF Networks?!
I think that we are not the only that have this problem…
In Log are many Entries “Database description failure” ect.
But the config is definitivley ok and very simple. We have it checked many times.
On my last post on autosupout.rif to MT there was a answer:
“Problem is known and we will fix it in next release”
This was far away in 8/11 and now with 5.8 is also the same.
MT - please fix this very fast!
best regards
Christian
It makes me slightly happier to know im not alone..
Been waiting since version 5.4 for this to get rectified
ps:are you using ubnt equipment for backhauls? that also seems to be a common denominator
