Hi all,
I am having an odd error come up when using OSPF (with MD5) between a Cisco 2821 and several RB450G. OSPF mode is point to multipoint since while everything is on the same Ethernet segment, communication between RB is not allowed.
Clocks on all devices are synced to the same NTP server. I have tried this with RouterOS 4.10 and also 4.13 and even upgraded the firmware version to 2.28 however I am still having this problem.
Is this a known issue, or should I email support?
15:22:56 route,ospf,info Invalid sequence number
15:22:56 route,ospf,info mine=1291263188
15:22:56 route,ospf,info received=1291263159
15:22:56 route,ospf,info Discarding packet: MD5 authentication failed
15:22:56 route,ospf,info source=10.60.10.1
15:23:00 route,ospf,info Invalid sequence number
15:23:00 route,ospf,info mine=1291263188
15:23:00 route,ospf,info received=1291263187
15:23:00 route,ospf,info Discarding packet: MD5 authentication failed
15:23:00 route,ospf,info source=10.60.10.1
15:29:19 route,ospf,info Invalid sequence number
15:29:19 route,ospf,info mine=1291263588
15:29:19 route,ospf,info received=1291263550
15:29:19 route,ospf,info Discarding packet: MD5 authentication failed
15:29:19 route,ospf,info source=10.60.10.1
15:29:37 route,ospf,info Invalid sequence number
15:29:37 route,ospf,info mine=1291263588
15:29:37 route,ospf,info received=1291263578
15:29:37 route,ospf,info Discarding packet: MD5 authentication failed
15:29:37 route,ospf,info source=10.60.10.1
