ospf its no use saying there is a good example in the manual still dont get it cant someone setup a step to step example using winbox on how you set it up i want to winbox through 3 rb532 and winbox to the 4th routerboard thanx
set up ip addresses on first router, set up OSPF as in manual, then set up address (if there is none) on next router and set up OSPF so it redistributes netwrks available, and continue while you have all the routers set up
then on your GW router set to redistribute static, so default gateway gets distributed all over your link.
if you closely follow manual you should end with working OSPF network.
also, usually CLI commands have same name as its winbox siblings
