OSPFv3 and LSA 7
I have a CCR1009 with V6.43.11 into NSSA AREA 30 with different routes of PPPOE sessions in IPV6. The routes appears in the routing table and they are reachable from the 1009 itself but they are not announced properly to the rest of routers in AREA 30 and the ABRs and then, they can not be reachable. I can see it in the LSA in OSPFv3 without gateway. I think that I'm missing something to configure into OSPFv3 configuration but I'm not able to find it out.
The IPV6 pool is assigned by radius, but I also configured a L2TP tunnel assigning the pool by a profile and it happens exactly the same, so I guess is not a problem of radius pool assignment.
Routing table in CCR1009:
28 ADS 2a00:XX:ca5a:100::/64 fe80::f%<pppoe-oscarn... 1
OSPFv3 LSA in CCR1009:
instance=3333 area=area30 type=type-7 id=0.0.0.1 originator=10.0.0.40 sequence-number=0x80000122 age=1399 checksum=0x1DDF options="" body=
forwarding-address=::
prefix=2a00:XX:ca5a:100::/64 options=00000000
referenced-LS-type=0
referenced-LS-ID=0
metric=20
route-tag=0x0
type1
OSPFv3 interfaces:
[admin@rt-ch-03] > routing ospf-v3 interface print
Flags: X - disabled, I - inactive, D - dynamic, P - passive
INTERFACE AREA COST PRIORITY NETWORK-TYPE
0 vlan30 area30 10 1 default
1 area30 10 1 default
2 pppoe-oscarneba2@voztele area30 10 1 default
OSPFv3 config:
/ipv6 pool
add name=pool-CA5A-100 prefix=2a00:XX:ca5a:100::/64 prefix-length=64
/routing ospf-v3 area
/routing ospf-v3 instance
add comment="OSPF area 30" metric-bgp=20 metric-other-ospf=20 name=3333
redistribute-connected=as-type-1 redistribute-other-ospf=as-type-1
redistribute-static=as-type-1 router-id=10.0.0.40
add area-id=0.0.0.30 default-cost=1 inject-summary-lsas=yes instance=3333
name=area30 translator-role=translate-never type=nssa
/ipv6 address
add address=2a00:XX:0:10a::b/128 advertise=no comment="Loopback 6 - IPV6"
interface=Loopback6
add address=2a00:XX:0:103::9 advertise=no comment="AREA 30 - OSPF - VLAN 30"
interface=vlan30
Neighbor router of AREA 30 can see the OSPF session established
/routing ospf-v3 ospf-router> print
AREA ROUTER-ID STATE GATEWAY COST
3 area30 10.0.0.40 intra-area fe80::6e3b:6bff:fee4:8102 10
LSA on neighbor router
instance=3333 area=area30 type=type-7 id=0.0.0.4 originator=10.0.0.40
sequence-number=0x80000105 age=1035 checksum=0x4ACB options="" body=
referenced-LS-ID=0
metric=20
route-tag=0x0
type1
As I said, I don't know if I missed something to configure in order to announce properly the static routes. I supposed I should have anything special to announce static routes, as far as I know, there is no filters in OSPFv3.
