We have two CCR 1036’s running v6.34.3
They WILL form OSPFv2 adjacency just fine.
The WILL NOT form OSPFv3 adjacency and stay stuck in Exstart and dropping from Full to 2-Way.
I’m trying to bring IPv6 up on these new links hence the OSPFv3.
The two routers are interconnected via a pair of AirFiber 24’s
I do NOT believe this to be a MTU issue as
a) OSPFv2 is working
b) the AirFibers support MTU 9000 and the CCR’s are 1590
relevant config snips
psr07:
/routing ospf-v3 instance
set [ find default=yes ] router-id=XXX.XXX.XXX.28
/routing ospf-v3 interface
add area=backbone interface=eth11-uplink network-type=point-to-point ← To Cisco 3560G WORKS
add area=backbone interface=eth2-af24-505-5301 network-type=point-to-point ← BROKEN
/ipv6 address
add address=XXXX:XXXX:a000:105::2/126 advertise=no interface=eth11-uplink
add address=XXXX:XXXX:a000:106::1/126 advertise=no interface=eth2-af24-505-5301
add address=XXXX:XXXX:a000:103::1/126 advertise=no interface=eth3-af24-505-6001
set [ find default-name=ether2 ] l2mtu=1590 name=eth2-af24-505-5301
log
mar/20 21:45:12 route,ospf,info OSPFv3 neighbor XXX.XXX.XXX.27: state change from Full to 2-Way
mar/20 21:45:13 route,ospf,info Database Description packet has different master status flag
mar/20 21:45:13 route,ospf,info new master flag=false
mar/20 21:45:13 route,ospf,info OSPFv3 neighbor XXX.XXX.XXX.27: state change from Full to 2-Way
mar/20 21:45:14 route,ospf,info Database Description packet has different master status flag
mar/20 21:45:14 route,ospf,info new master flag=false
mar/20 21:45:14 route,ospf,info OSPFv3 neighbor XXX.XXX.XXX.27: state change from Full to 2-Way
psr06: config / log
set [ find default=yes ] router-id=XXX.XXX.XXX.27
add area=backbone interface=eth1-af24-5301-505 network-type=point-to-point
/ipv6 address
add address=XXXX:XXXX:a000:106::2/126 advertise=no interface=eth1-af24-5301-505
set [ find default-name=ether1 ] l2mtu=1590 name=eth1-af24-5301-505
logs
03:49:09 route,ospf,info OSPFv3 neighbor XXX.XXX.XXX.28: state change from Loading to 2-Way
03:49:10 route,ospf,info OSPFv3 neighbor XXX.XXX.XXX.28: state change from Loading to 2-Way
03:49:11 route,ospf,info OSPFv3 neighbor XXX.XXX.XXX.28: state change from Loading to 2-Way
03:49:12 route,ospf,info OSPFv3 neighbor XXX.XXX.XXX.28: state change from Loading to 2-Way
03:49:13 route,ospf,info OSPFv3 neighbor XXX.XXX.XXX.28: state change from Loading to 2-Way
Thank you for your help.
