I’m currently evaluating a RB411 as a base station SBC for our PtMP wireless network. I’ve already configured and implemented OSPFv2 and so far, all went fine. However, I decided to configure OSPFv3 as well, in order to have a similar routing configuration with IPv4. During my tests, I encountered a few “glitches” and an important issue with LSAs.
The routerboard is connected to a Juniper firewall running JUNOS, and the following has an uplink to a Cisco router. I followed the procedure for which I am accustomed, to configure the RB411, like configuring a loopback address, configuring the areas and so on.. I first came to the conclusion that a few important features are missing (as for ospfv2), like the reference-bandwidth command (that would be pretty useful for a higher-end board). Then, once OSPFv3 was configured, I discovered that a prefix was missing from the routing table, despite the fact the corresponding LSA was present in the ospf’s database. Here’s the output of the database:
[eprom@WAP2] > /routing ospf-v3 lsa print detail
instance=default area=area2 type=link id=0.0.0.1 originator=10.2.3.1
sequence-number=0x8000000A age=2297 checksum=0xF0C0 options="V6|E|R|DC"
body=
on=vlan500
priority=128
local-address=fe80::b2c6:9a01:f473:8482
prefix=2001:620:2010:200::/64 options=00000000
instance=default area=area2 type=link id=0.0.0.9 originator=10.2.3.2
sequence-number=0x80000009 age=996 checksum=0xA9D7 options="V6|E|R"
body=
on=vlan500
priority=1
local-address=fe80::20c:42ff:fe4d:842b
instance=default area=area2 type=router id=0.0.0.0 originator=10.2.3.1
sequence-number=0x8000000C age=1226 checksum=0xE7E9 options="V6|E|R|DC"
body=
flags=
link-type=Transit iface-id=1 neighbor-iface-id=1 neighbor-routerId=10>
instance=default area=area2 type=router id=0.0.0.0 originator=10.2.3.2
sequence-number=0x80000008 age=996 checksum=0xF3EF options="V6|E|R"
body=
flags=
instance=default area=area2 type=network id=0.0.0.1 originator=10.2.3.1
sequence-number=0x80000007 age=876 checksum=0x9A36 options="V6|E|R|DC"
body=
routerId=10.2.3.1
routerId=10.2.3.2
instance=default area=area2 type=intra-area-prefix id=0.0.0.1
originator=10.2.3.1 sequence-number=0x8000000F age=148 checksum=0x5E56
options="" body=
referenced-LS-type=Router LSA
referenced-LS-ID=0
prefix=2001:620:2010:2fe::c/126 options=00000000
prefix=2001:620:2010:203::1/128 options=01000000 (LA)
instance=default area=area2 type=intra-area-prefix id=0.0.0.2
originator=10.2.3.1 sequence-number=0x80000007 age=526 checksum=0x56CC
options="" body=
referenced-LS-type=Network LSA
referenced-LS-ID=1
The routing table is missing the advertised “2001:620:2010:203::1/128” prefix, as shown below:
[eprom@WAP2] > /ipv6 route print
C - connect, S - static, r - rip, o - ospf, b - bgp, U - unreachable
# DST-ADDRESS GATEWAY DISTANCE
0 ADC 2001:620:2010:200::/64 vlan500 0
1 ADC 2001:620:2010:202::/64 vlan502 0
2 ADC 2001:620:2010:203::2/128 lo0 0
3 ADo 2001:620:2010:2fe::c/126 fe80::b2c6:9a01:f473:... 110
I also encountered another issue, where the router fails to install LSA originated from the Cisco router. Here’s an extract of the logs:
15:49:35 route,ospf,warning LSA installation failed
15:49:35 route,ospf,warning header=Summary Network LSA id=0.0.0.78 originator=10.2.255.1 seqnum=0x800005b6
15:49:35 route,ospf,warning header=Summary Network LSA id=0.0.0.79 originator=10.2.255.1 seqnum=0x800005b6
Any pointers or suggestions regarding the issue?
