I have a pretty straightforward OSPFv3 configuration with three (in future 4) routers - Configuration details see below.
However, whenever I add an IPv6 address to an interface (no mater if it is a “real” physical - like ehter 1, or a VLAN interface) the new subnet is not announced to the other routers.
Example:
Router 3 get the following address on his Test-VLAN Interface
add address=2001:470:747c:666::1 advertise=no interface=vlan666
The subnet-mask is 64
OSPFv3 route-list on Router 1 looks like this:
/routing ospf-v3> route print
# DST-ADDRESS STATE COST
0 2001:470:1f0a:113::/64 ext-1 10
1 2001:470:747c:10::/64 intra-area 10
2 2001:470:747c:144::/64 ext-1 10
3 2001:470:747c:220::/64 ext-1 10
4 2001:470:747c:2201::/64 intra-area 10
5 2003:0:0:5::/64 imported-ext-1 20
6 fe80::/64 ext-1 10
OSPF with IPv4 works without any problems - firewalls are pretty much opened as they currently only reside in their own closed subnet.
I’m pretty unsure what could leads to this problem - maybe someone has a solution…
Configuration
Routers
Router 1
/system routerboard print
routerboard: yes
model: CRS125-24G-1S
serial-number: 73800594C431
firmware-type: ar9344
factory-firmware: 3.33
current-firmware: 3.33
upgrade-firmware: 3.33
Router 2
routerboard: yes
model: 912UAG-5HPnD
serial-number: 6812052F32C4
firmware-type: ar9340
factory-firmware: 3.24
current-firmware: 3.24
Router 3
routerboard: yes
model: 953GS-5HnT
serial-number: 49C504499B54
firmware-type: qca9550
factory-firmware: 3.16
current-firmware: 3.29
upgrade-firmware: 3.34
Instances
Router 1:
[admin@switch] /routing ospf-v3> instance print
Flags: X - disabled, * - default
0 * name="switch" router-id=192.168.10.6 distribute-default=never
redistribute-connected=as-type-1 redistribute-static=as-type-1
redistribute-rip=as-type-1 redistribute-bgp=as-type-1
redistribute-other-ospf=as-type-1 metric-default=1 metric-connected=20
metric-static=20 metric-rip=20 metric-bgp=auto metric-other-ospf=auto
Router 2:
[admin@main] > /routing ospf-v3 instance print
0 * name="main" router-id=192.168.10.2 distribute-default=never
redistribute-other-ospf=as-type-1 metric-default=1 metric-connected=10
Router 3:
[admin@backup] > /routing ospf-v3 instance print
0 * name="backup" router-id=192.168.10.3 distribute-default=never
Area
Router1:
/routing ospf-v3 area-id=0.0.0.0 disabled=no instance=switch name=backbone type=default
Router 2:
/routing ospf-v3 area-id=0.0.0.0 disabled=no instance=backup name=main type=default
Router 3:
/routing ospf-v3 area-id=0.0.0.0 disabled=no instance=backup name=backbone type=default
Interfaces
Router 2 and Router 3 are only listening on VLAN Interfaces for Updates. Router 1 also has a OpenVPN Tunnel to an external server - which will be my IPv6 gateway to the internet - but that currently can be ignored.
Router 1
/routing ospf-v3 interface print detail
Flags: X - disabled, I - inactive, D - dynamic, P - passive
0 area=backbone interface=vpn-de cost=10 priority=1 network-type=default
retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s
instance-id=0 use-bfd=no
1 area=backbone interface=vlan10 cost=10 priority=1 network-type=default
Router 2
0 area=backbone interface=VLAN10 cost=10 priority=1 network-type=default
dead-interval=40s instance-id=0 use-bfd=no
Router 3
