Hello everyone!
I can’t summarize routes in ospfv3 in a simple way like ospfv2, does anyone have any howto that really works that they can share?
Thank you all!
What you can do is add the IPv6 supernet that all of your PPPoE customers are in on a loopback bridge, give the loopback bridge the last address in that supernet. Then you don’t have to advertise the individual blocks that you allocate to each customer.
Thanks for the help friend, this was the only way it worked, I particularly think it is a failure of Mikrotik that should work with a static route.
