OSPFv3 routes not active
Hi
I am setting up ospfv3 in in conjunction with juniper routers.
The routes are correctly distributes between juniper’s,
the mikrotik ccr is receiving the routes, but they are not active in the routing table.
ipv6 route table:
http://i.imgur.com/BElrSqP.png
As you can see, the routes are blue or purple
What could be the reason for them not to be active?
ospfv3 configuration:
http://i.imgur.com/mQG5R5H.png
http://i.imgur.com/Nsdn2hM.png
http://i.imgur.com/70m4TzQ.png
The neighbor is visible at the neighbors tab (ospfv3)
The routes are also visible at the routes tab in ospfv3.
The problem is they are not installed, they stay inactive.
I am running 6.19 on CCR1036-8G-2S+
