Hi everyone!
When I have static routes registered in my router, and I enabled the option "Redistribute Static Routes" in the instance of OSPFv3, and try to summarize them in the "Area Ranges" of Mikrotik, the summarization does not work.
/routing ospf-v3 area
add area-id=0.0.0.2 name=area2
/routing ospf-v3 instance
set [ find default=yes ] redistribute-static=as-type-1 router-id=10.0.2.1
/routing ospf-v3 area range
add area=area2 range=2001:db8::20/124
add area=area2 range=2001:db8:210::/45
/ipv6 route
add dst-address=2001:db8:214::/64 gateway=ether3
add dst-address=2001:db8:215::/64 gateway=ether3
add dst-address=2001:db8:216::/64 gateway=ether3
Another router im my network:
DST-ADDRESS GATEWAY DISTANCE
12 ADo 2001:db8:210::/45 fe80::d6ca:6dff:fe53:... 110
13 ADo 2001:db8:214::/64 fe80::d6ca:6dff:fe53:... 110
14 ADo 2001:db8:215::/64 fe80::d6ca:6dff:fe53:... 110
15 ADo 2001:db8:216::/64 fe80::d6ca:6dff:fe53:... 110
