OSPPF 3.14
in version 2.9.x i could have 2 gateways (first came dynamicly from OSPF and second was set staticly on one interface for backup - distance set to 200) Now in 3,14 when dynamic gateway disapear (because router with first gateway is down) static gateway is working fine as a default gateway and is redistributed to whole network. Until this it’s OK. But when first router with first default gateway is working again all routes are updated except dynamic default route on router with second (backup) GW which was default till now. What helps is disable static default gateway then dynamic gateway is back and now enable static gateway . Is it normal? I thought tat is should work fine with different distance .
thanks for any help . and ask if anything is not clear .
thanks a lot
