Hi, it is possible to use AiMesh from Asus on RouterOS ?
I have two Asus APs with the AiMesh function, which I would connect to a Mikrotic router (crs326-24G-2S+ IN). However, I need the AiMesh connection between these Asus routers to work via an ethernet cable, not WIFI. They are far from each other for the WiFi connection to work.
I already had it connected this way, but the problem is that the AiMesh connection via an Ethernet cable only works if the AiMesh node is connected directly to the AiMesh server.
So I would need advice if it is possible to somehow configure in RouterOS so that these two Asus APs are seen as if they are connected directly ?
