Hi ,
I have also this probs to pass a variable :
<?php
$ip=$_POST['ip'];
<script>
var unbinding = document.getElementById('unbind');
unbinding.innerHTML = '<iframe src="http://xxxxx/binding-off.php?ipclient=$ip" "width="1" height="1"></iframe>';
</script>
If i use a static value like 192.168.0.250 inside innerHTML the code work . If i use a variable $ip ( passed from other php code ) don’t work. Again sintax probs ?
Thanks in advance.
brasileottanta
Yep.
You must trigger PHP with “<?php” to access PHP variables:
<?php
$ip=$_POST['ip'];
unbinding.innerHTML = '<iframe src="http://xxxxx/binding-off.php?ipclient=<?php echo $ip; ?>" "width="1" height="1"></iframe>';
boen_robot:
Yep.
<?php
$ip=$_POST['ip'];
Thanks. It’s incredible how complex is the sintax . When all job work , I traslate in native PHP .
Regards
brasileottanta
