My router rebooted twice so far today, and after rebooting I found this message:
“system,error,critical System rebooted because of kernel failure
system,error,critical Out of memory condition was detected
system,error,critical router was rebooted without proper shutdown”
after the router has been rebooted I notice high CPU usage and traffic coming through one of the local interfaces! After using Torch I noticed the traffic coming from a local IP address, I also found weird negative DNS entries in the cache!
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" \
disabled=yes
add action=accept chain=input comment="Accept ICMP" protocol=icmp
add action=accept chain=input comment="Accept established and related" \
add action=drop chain=input comment="Drop invalid" connection-state=invalid
add action=drop chain=input comment="Drop all from WAN" in-interface=WAN1
add action=drop chain=input comment="Drop all from WAN" in-interface=WAN2
add action=accept chain=forward comment="Accept established,related" \
add action=drop chain=forward comment="Drop invalid" connection-state=invalid
add action=drop chain=forward comment="Drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface=WAN1
connection-nat-state=!dstnat connection-state=new in-interface=WAN2
add action=drop chain=forward comment="Drop all packets in local network which d\
oes not have local network address" in-interface=LAN src-address=\
!192.168.0.0/24
Did you increase the cache size for your DNS resolver to a value that is more than the RAM you can spare for this? (depending on the router model)
Or is there something else that consumes a lot of memory, e.g. the firewall connection table? What does “free memory” say in System->Resources?
It may well be that someone is attacking your network by doing lots of unresolvable DNS queries, but with proper limits it should not crash the router.
So, It definitely was an SYN flooding attack! And I solved the problem by limiting connections!
add action=add-src-to-address-list address-list="Input Syn_Flooder" \
address-list-timeout=5s chain=input comment=\
"Add Syn Flood IP to the list" connection-limit=50,32 protocol=tcp \
tcp-flags=syn
add action=drop chain=input comment="Drop to syn flood list" \
src-address-list="Input Syn_Flooder"
But now I’m facing another problem! I’m running a hotspot server and after adding the above rules, authenticating hotspot clients seems to be considered as an SYN attack or something Increasing the connections limit to more than 100 seems to solve the problem, but I think it’s a high number!
I wonder if there’s a way to exclude hotspot authentications from the connections limit rule? or add the IP address to the list after 5 seconds from exceeding the limited connections, so that clients could log in to the hotspot before adding their IP addresses to the list!
