Out of the box solution?
I’m a small ISP delivering service to MDUs. I’ve been looking for a dependable dual wan router solution with hotspot functions, load balancing, P2P throttling, and QoS. Using Peplink 20s now and they work great but lack the detailed functions.
Does anyone know where I can buy out of the box MT 450G routers pre-configered? I do not have time to learn the OS. Any one in Denver, CO or close by? Thanks!!!
There is no such thing as preconfigured router for your needs. If you don’t have time to learn, then we have a list of consultants that can do configuration for you:
http://www.mikrotik.com/consultants.html
Have contacted 2 of your consultants. No help. Not even a response. I suggest you you re-evaluate the “consultants” on your list.
We have actually transitioned our network from Peplinks to complete MikroTik solution. I am also on the consultant list and would be willing to see if we can help you.
