Outage Problem
A bit of a stange one.
In Outages I have listed the few active ones that are correct, then I have about 15 that have been active for 32 and 50 days. None of these have a device name against them, if I select device settings there is no response, its like they are rouge.. Is there a way to another way to remove them as if I try it gives me the error “cannot remove active outage”
If it is RB532s or RB112 I have had problems in that sometimes during brownouts or power flickers the devices go into “lala” land, they are still connected to the AP, and they respond to ping from the AP, but not anything past the AP.
They require a manual reboot, software reboot reports back with an error.
On my Dude setup they will be reported as down (and rightly so, as they are not responding correctly), but again they are still connected to the AP.
We have no router boards in the network… The dude seems to be looking for ghost devices that used to be there but are no loger and marking them as down… except i cannot find them or remove them…
can you send your export file to support@mikrotik.com
