can I clear the outages list
would like to clear one device at a time or all of them at the same time
thanks
thanks
you have a “remove resolved” button in the outages tab. at least in v4
The remove resolved button on the services->outages page does not work (at least on my dude server).
A workaround for now is to double click on an outage that will take you to the device and on it’s outage tab the remove resolved button works.
Thanks for the help
I thought I had seen “remove resolved” before but its not there anymore? 4.0 beta 1
Might be me: (just out of surgery)
Tried to attach print screen file but it is too large
just went to beta 2 and the transition was smooth
everything came back up with the “remove resolved” and it works
thank you Normis: There has been a lot of criticism in other forums about how cold people were here regarding getting help. I must say I do not agree with them. Thanks again all
Lebowski: I spoke to soon
yes the “remove resolved” works. When I turned by bac they all re appeared ![]()
I followed your instructions and that works but it could be a long process to clear them all out.
Minor bug, they will get it for next release, I hope. For everything that the dude does do it is one amazing piece of software.
