Hey All
Just wondering what you guys are using for outdoor enclosures. We are using Alix boards with Router OS and currently using these enclosures.
http://www.mini-box.com/WRAP-BOX-4A2E_2
We are finding the seals fail on the ethernet assembly and the pins corrode killing the unit.
We are looking at enclosures but can’t really find something suitable. Do any of you have recommendations
Cheers
Luke
I’ve been using these two without problems:
http://www.interprojekt.com.pl/gold-alubox-outdoor-case-with-wateproof-ethernet-socket-p-472.html
http://www.interprojekt.com.pl/scame-universal-outdoor-enclosure-ip66-alix-p-219.html
EDIT: I use hot glue around the N connectors inside the case. And outside the case i use waterproof tape around the connectors.
You can also find here, they are not cheap, but they are military grade and are compatible with all Routerboards.
http://www.mikrotikoutdoorenclosures.com/
