Is there a Mikrotik 5G modem/router (no Wifi needed) that could reside outdoors? Looking a replacement for https://ztemobiles.com.au/mc-7010/
Thank you.
All Mikrotik’s devices, which can connect to mobile broadband, are listed on this product list. There aren’t very many 5G products on the list, if I see correctly there’s only a single 5G device listed: Chateau 5G ax which doesn’t fit your requirements (it’s not an outdoor device).
So it does seem you can’t use MT product to replace that ZTE yet.
Maybe you could use one of the indoor 5G routers from MT and add an external, outdoor 5G antenna?
Maybe on a couple of years more, will we have an outdoor 5G solution, or when 6G will be released. I don’t expect outdoor 5G device soon.
Regards.
