outgoing DOS protection for hotspots
I have a hotspot that has recently been used to DOS others. Thus I want to limit the maximum number of connections to the same destination IP’s.
I have seen incoming DOS protection in this forum where someone set up a filter with connection limiting like 10,32 where 10 is the number of connections and 32 is the IP mask of the originating address … so in this case the same IP starts all 10 connections.
I want to do the same, but I want to control the destination IP and not the source IP … since my hostpot is the source IP.
Does anyone know how to do this? … or someone explain to me if the filter parameters regarding the connection limiting have different meaning for incoming, forward and the output chain?
GL
You can limit them on the forward chain of the filter rules.
This is what we are currently using on our hotspot:
add action=drop chain=forward comment="" disabled=no in-interface=\
    "Guest Network" src-address-list=abuse
add action=add-src-to-address-list address-list=abuse address-list-timeout=2h \
    chain=forward comment="" connection-limit=200,32 disabled=no \
    in-interface="Guest Network" protocol=tcp src-address=192.168.50.0/23 \
    src-address-list=!Do-Not-Block
add action=log chain=forward comment="" disabled=no log-prefix=\
    "Abuse Limit Reached" src-address-list=abuse
If anyone has more than 200 TCP sessions open at once it will add them to an address list and drop all of their packets for the next 2 hours. It also adds a line to the log that the abuse limit was reached, so if you have it sending the logs to a different server you can review if/when someone was blocked. It also lets you set up an address list of IP addresses that you do not want to block, so if you have a permanent computer or price of hardware it will be exempt from these rules.
