how do i control to which ports can the internal LAN clients access?
i want to setup so that they can access a specific set of services as i’m seeing some strange traffic that eats my BW, so i added a rule on the forward chain with accept forward 80, 8080 on tcp
then i have a couple of block all rules on the input and forward chain with all drops
the rule is doing nothing, as i’m seeing with torch a ton of UDP packets from lan to wan…
these are my rules:
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=yes tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="Accept established input" connection-state=established disabled=no
add action=accept chain=input comment="accept related input" connection-state=related disabled=no
add action=accept chain=input comment="" disabled=no dst-address=255.255.255.255 dst-port=5678 in-interface=ether3-local-master protocol=udp
add action=drop chain=input comment="drop invalid input" connection-state=invalid disabled=no
add action=drop chain=forward comment="drop invalid forward" connection-state=invalid disabled=no
add action=drop chain=input comment="detect and drop port scan connections" disabled=no protocol=tcp psd=21,3s,3,1
add action=accept chain=forward comment="accept new connections" connection-state=new disabled=no
add action=accept chain=forward comment="" disabled=no dst-port=80,8080 protocol=tcp
add action=accept chain=forward comment="allow related forward" connection-state=related disabled=no
add action=accept chain=forward comment="accept established forward" connection-state=established disabled=no
add action=accept chain=input comment=winbox disabled=no dst-port=8291 protocol=tcp
add action=accept chain=input comment="" disabled=no dst-port=53 in-interface=ether3-local-master protocol=udp
add action=accept chain=input comment="Allow ICMP ping" disabled=no icmp-options=8:0-255 limit=50/5s,2 protocol=icmp
add action=drop chain=forward disabled=no
add action=drop chain=input comment="default configuration" disabled=no
the last drop forwrd rule gets no hits at all, the established one takes everything away…, any ideas on how to implement a “allow XX ports only”? i’ve searched the examples and found nothing of much use or simplicity
