Output route selection - Wireguard
Im for whatever is simple, and works......
Just need to know limitations.......
That's double nat. Either variation works reliably.
??? double nat ??? From my limited experience double nat is when you have two routers involved........
Meant srcnat and dstnat to the address or address pair. Poor choice of words.
Hi @lurker888 , I'm trying to understand your answer, could you please explain it in more detail?
Here’s the basic configuration I’m using to get WireGuard working:
/interface wireguard add comment="WireGuard" listen-port=12345 mtu=1432 name=WG private-key="..."
/interface wireguard peers add allowed-address=10.0.0.0/24 comment="WG Peer" endpoint-address=my.ip endpoint-port=12345 interface=WG responder=yes public-key="..."
/ip firewall filter add action=accept chain=input port=12345.... in-interface-list=WAN
/ip address add address=10.0.0.1/24 interface=WG
/interface list member add interface=WG list=LAN
(this is enough on my side, without any src-nat rule added)
Situation 1: We have two WANs, both with public IP, we want WG to always respond and then maintain a connection on whichever WAN the connection came in on:
  • If we aren't afraid of losing the primary route and address, a dstnat rule -> /ip firewall nat add action=dst-nat chain=dstnat dst-address=? dst-port=12345 in-interface=WG protocol=udp to-addresses=?
  • If we are afraid of losing the primary wan -> (this seems to be something @anav explained in Output route selection - Wireguard - #32 by anav)
Situation 2. We have two WANs, WAN1 with private IP and WAN2 with public IP, we know that we always want to use a given WAN connection for WG:
  • /ip firewall nat add action=src-nat chain=srcnat out-interface=WG to-addresses=10.0.0.1
  • /ip firewall mangle add action=mark-routing chain=output new-routing-mark=WG protocol=udp src-port=12345 out-interface=WAN2?
  • Do we also need a route and a routing rule here?
Sorry if my understanding is limited, still learning!
It's time I wrote out a tutorial for the full solution. I'll reserve some time for it.
I hope you're willing to test it?
The more you describe the requirements the better the answers will be!
For example in Scenario1&2, Is PRIMARY WAN1, FAILOVER WAN2
or
LOADBALANCING the two WANs.
What is the purpose of the WIREGUARD on this device?
What are you connecting to/from over wireguard??
An approach and answers are predicated upon undertanding what traffic flow you are trying to establish and why.
Appreciated! Of course will test all the scenarios you suggest.
@anav , request is more theoretical than a real necessity, I was following the main post to remain on topic, but there is always room for improvements or learning.
I have main WAN and failover with the config posted above working + a site-to-site, can't complain.
WireGuard is used to access the device remotely and browsing Uptime-Kuma located outside (via S2S).
I work from facts, and problems needed to be solved, so not so helpful on theory............
Is MikroTik reading the forum? :slight_smile:
@lurker888
