Hi, I have a RB532 with a daughterboard RB564.
The issue is that I have overclocked it, from 264MHz to 330MHz. After that I keep the frequency and upload the rb500-2.9.39 mikrotik version to the board (it had the rb500-2.9.38 )
When I finished that, I run “/system shutdown” and then I plug out and after a few seconds plug in the board again, but nothing happen.
I connect a RS232 cable to see what the board is prompting, and I see the next lines:
RouterBOOT booter 2.6
RouterBoard 532
CPU frequency: 330 MHz
Memory size: 32 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
System halted.
I reset it a lot of times, underclock it, upgrade the firmware, but nohingg happend.
Could you help me?
Thanks,
Julian.
