F.J.S
1
I used command:
/system routerboard settings set cpu-frequency=180MHz
I got
input does not match any value of cpu-frequency
What’s wrong?
I tested even 200MHz and 264MHz, everything same.
Only 175MHz accepted. Why?
It is RB112, RouterOS 2.9.28, firmware 1.14
normis
2
what do you get at the cpu-frequency= when you type TAB twice ?
normis
4
sorry, setting of this value only works on RB500 series
I setted RB112 to 200Mhz by adding 1khz resistor to R7 position and jumper on JP7. Works fine
F.J.S
6
Which transfer did you reach?
Cant remember exactly, but it was about 14% increase.
Same graduality as on RB532.
