we do have a 114 m long Cat 7 Ethernet Cable in a server housing center, their room layout is so Sh** that you always get very long connections.
That cable worked good with a Routerbord 2011 with gigabit connection for 3 years, now it starts making problems.
I wonder which mikrotik products ethernet has “most” reserves for me beeing used for my long cable. I’d prefer a mikrotik product, but I could also use any recommended third party switch as a repeater.
It mostly depends on the cable itself. Sometimes when a cable is aging it just degrades and a long link just starts making problems.
You can start by replacing the connectors and see what happens.
I’ve seen some of the dumbest switches you can find perform good in this scenario.
You could always put a PoE-powered switch somewhere in the middle of that long cable run in order to remain within the official 100m limit of Ethernet.
this is a server housing center, you have to buy the (overlenght) patches from them, and may not place any equpiment somewhere in between.
you may even not make a patch yourself, just plugging in a patch cable costs eur 650 each (if cables are present).
is there any difference between a “dump cheap switch” or the switch chip of the 2011 ?
