Good day to everyone!
RoS 6.49.13
Received through BGP a route for a destination х.х.х.0/23, put it in custom routing table and assigned it a secondary gateway.
But for a single /32 address in that range I need to use default gateway from main routing table. How can I do that?
Tried creating route rule with a specific destination and “lookup-only-at-table main” rule, but that does not work.
For now had to drop entire range, but that is not a solution.
Appreciate the help )
lol posted and found a solution the same minute )
Just had to add a static route to BGP routing table.
