Override channel selection CAPsMAN
Hi all, i have CAPsMAN running and for the most part works fine.
I am finding however that channel selection can be a bit hit and miss (some 2GHz APs are selecting the same channel - i had defined 1, 6 and 11 for these).
Is there any way with the setup (where i have defined the channels available, and bound each of the frequency sets to a configuration) where i can override the auto selected channel and instead use a manual one (from the defined list or otherwise) of my preference?
