How do I achieve overwriting existing files in scheduler and scripts with updated versions!
How do i workaround “failure: item with this name already exists”
And there must be a better way than having this at the start of the script;
/system scheduler remove numbers=0
/system scheduler remove numbers=1
/system scheduler remove numbers=2
/system scheduler remove numbers=3
/system scheduler remove numbers=4
/system script remove numbers=0
/system script remove numbers=1
/system script remove numbers=2
/system script remove numbers=3
/system script remove numbers=4
To add something, use “add”. To change something, use “set”.
I tried “set” but it stops when it reaches “owner=…”
