I’m experimenting with version 7.x in particular 7.10.1
Routings let’s say they work, I still have to study but everything seems to work.
I’m having problems with OVPN though
The client connects but then doesn’t seem to surf the lan. as if proxy-arp doesn’t work
I do not understand. I tried a very simple configuration
2023-07-10 18:44:54 by RouterOS 7.10.1
software id = H685-EVH0
model = RB4011iGS+
serial number = HDH08ZH69EA
add arp=proxy-arp name=lan
/interface pppoe-client
add disabled=no interface=ether10 name=pppoe-isp1 user=XY1234567
add name=dhcp_Pool_Lan ranges=192.168.32.101-192.168.32.139
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
add bridge=lan local-address=192.168.32.1 name=profileOVPN remote-address=
dhcp_Pool_Lan
add bridge=lan interface=ether1
add bridge=lan interface=ether2
add bridge=lan interface=ether3
add bridge=lan interface=ether4
add bridge=lan interface=ether5
add bridge=lan interface=ether6
add bridge=lan interface=ether7
add bridge=lan interface=ether8
add bridge=lan interface=ether9
/interface ovpn-server server
set auth=sha1 certificate=OVPNServer.crt_0 cipher=aes256-cbc
default-profile=profileOVPN enabled=yes redirect-gateway=“”
add address=192.168.32.1/24 interface=lan network=192.168.32.0
set servers=8.8.8.8,1.1.1.1
add action=masquerade chain=srcnat out-interface=pppoe-isp1
add disabled=no dst-address=0.0.0.0/0 gateway=pppoe-isp1 routing-table=main
suppress-hw-offload=no
/ip service
set telnet disabled=yes
set www disabled=yes
/ppp secret
add name=testOVPN profile=profileOVPN service=ovpn
/system clock
set time-zone-name=Europe/Rome
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
I also tried with the develope 7.11beta4 version but the problem is not resolved.
Am I doing something wrong? On version 6.49.8 it works correctly
