OVPN bottleneck issue
I’m trying to figure out why L2TP or OVPN connections are slow for TCP when device CPU is not overloaded. I setup a test using UDP OVPN between two routers. The routers are directly connected via 1Gb ethernet port. I setup the OVPN client to use null auth and null cipher.
Client Router - CCR2004 (ROS 7.16.2)
Server Router - CCR2116 (ROS 7.16.1)
When I run a bandwidth test between them (both directions) from Client router, I get:
TX/RX Total Average: 396.5 Mbps/62.8 Mbps
Client router CPU during test:
CPU LOAD IRQ DISK
0 cpu0 31% 11% 0%
1 cpu1 47% 19% 0%
2 cpu2 45% 30% 0%
3 cpu3 44% 13% 0%
Server router CPU during test:
CPU LOAD IRQ DISK
0 cpu0 3% 0% 0%
1 cpu1 1% 0% 0%
2 cpu2 3% 0% 0%
3 cpu3 6% 0% 0%
4 cpu4 0% 0% 0%
5 cpu5 8% 0% 0%
6 cpu6 33% 21% 0%
7 cpu7 7% 0% 0%
8 cpu8 5% 0% 0%
9 cpu9 2% 0% 0%
10 cpu10 6% 0% 0%
11 cpu11 1% 0% 0%
12 cpu12 3% 0% 0%
13 cpu13 4% 0% 0%
14 cpu14 56% 31% 0%
15 cpu15 0% 0% 0%
What is the bottleneck causing these devices with ~50% free CPU to not handle more traffic? I have tried:
  • Added a change MSS rule applied to the TCP traffic to set MSS at 1400 or 1360.
  • Tried connection count of 20, 40 and 80. No significant difference between these
Slow L2TP or OVPN performance for TCP traffic often results from a combination of protocol inefficiencies, network conditions, and system configuration. By understanding and addressing the specific causes, such as TCP-over-TCP issues, MTU mismatches, or encryption overhead, you can significantly improve connection speeds. Consider modern protocols like WireGuard for performance issues.
In regard to flintham’s suggestions:
  1. TCP-over-TCP issues - This is a UDP tunnel so there is no TCP over TCP
  2. MTU mismatches - MTU is 1500 on upstream connection. MSS on TCP bandwidth tests was restricted to reserve 100 bytes to VPN overhead which is more than enough for this protocol
  3. Encryption overhead - Encryption is disabled on the tunnel
  4. Consider modern protocols like WireGuard for performance issues - This is not helpful. Wiregard requires static IP address on both ends. I run thousands of tunnels from locations without static IP addresses and am looking for a way to improve speed on these. It would require a large cost to convert and this makes no sense when there is clearly some kind of unnecessary software bottleneck contributing to this problem.
No, it does not: https://www.wireguard.com/#built-in-roaming
