Ovpn Certificate
Hi
From 5.26 and then i can not create certificates for ovpn. I have tried openssh and from mikrotik and i can not make the certificates KR. I am always see them as KT.
See one of the tutorials that i have followed
https://rbgeek.wordpress.com/2014/09/10/openvpn-server-setup-on-mikrotik-routeros/
What i am doing wrong ?
Thanks in advanced and sorry for my bad english
Hello mikrotik community, as this is my first post here!
I also haven’t been able to create certificates marked as KR as shown in all tutorials. But i think R stands for “Revoked” anyway, so thats no what you are looking for. T stands for trusted. I made the experience that certificates have to be exported using a passphrase in any case.
But maybe someone can help me with a related problem. I have a openvpn server and a client, both mikrotik devices. I can connect to the server and the tunnel will be established, but only if i disable “require client certificate”. Both the server and the client have certificates installed from the same CA ( a metaRouter vm). So my questions:
A tool which checks if certificates will fit together?
Any possibility to increase the verbosity of the log? (it just says terminated)
Anyone had luck running a CA on a router board metarouter?
greetings
