Hey guys,
First of all I love the router - it’s super powerful and is amazing.
I’ve been setting up a few tunnels and marking specific ip’s via different tunnels (only L2TP so far with PIA).
I stumbled upon an OVPN Client setup guide here: https://support.hidemyass.com/hc/en-us/articles/204558497-Mikrotik-Client-Setup and thought wow! that’s super simple so I downloaded an OpenVPN manual setup pack from CyberGhost (my second VPN) and proceeded to import the certificates and follow the guide.
I get to the end and discover that no matter what I do - the OVPN client wont open up to the destination server on port 443 (their UDP setup) - only port 80 (their TCP setup) and when it does connect on port 80 - it wont Rx any data back (image below)
An example of the connect/disconnect loop I see in logs is here:
The only thing I can think that could be wrong is some firewall/NAT rules.
PPP view and OVPN Client Dial Out tab.
The contents of the ovpn file are as follows
client
remote 1-au.cg-dialup.net 443
dev tun
proto udp
auth-user-pass
dhcp-renew
dhcp-release
resolv-retry infinite
redirect-gateway def1
persist-key
persist-tun
nobind
cipher AES-256-CBC
auth MD5
ping 5
ping-exit 60
ping-timer-rem
explicit-exit-notify 2
script-security 2
remote-cert-tls server
route-delay 5
tun-mtu 1500
fragment 1300
mssfix 1300
verb 4
comp-lzo
ca ca.crt
cert client.crt
key client.key
Can anyone possibly point me into the right direction into getting this to work?
Thanks for your time!
