Where to start, I guess.
I’ve tried with both a 493 and 1100. No luck connecting to the ovpn server at all.
I’m able to connect no problem using openvpn software on pc (Configuration/settings are confirmed good and server is UP.) Also all is reachable via icmp. i’m trying to connect to a ovpn server from vpngate.net for awesome localized browsing (but trying to do it via tunnel so i’m not disconnecting other things like work. So I intend to probably set some static routes to point certain traffic at the endpoint. (Though i’m open to ideas here, not here yet..)
All I get from system log is ovpn-out1: initializing, connecting - terminating disconnected. Not particularily helpful for debugging. I was a few versions behind but i’ve updated to current release candidates (believe i was 5.9 mipsbe. tried 6.13 and 6.33 and 6.30 and 6.33 powerpc on the 1100)
Still no luck.
For the curious:
/interface ovpn-client
add certificate=cert1.txt_0 cipher=aes128 connect-to=114.145.12.187 \
mac-address=02:21:A9:65:D9:1E name=ovpn-out1 password=vpn port=1718 user=\
vpn
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
Of the countless pptp and l2tp i’ve setup and used, its my first try at ovpn so maybe i’m doing something blatantly wrong; but reviewing guides and other forum topics on similar circumstance i can’t readily find a solution.. Any takers?
