Hello, I have been upgrading a number of Mikrotik Hex routers to 7.x in order to allow for OpenVPN UDP connections to a CHR. This has worked for several but I am now encountering some units that just don’t seem to have the UDP option when creating the connection. it’s just NOT there…? They appear identical in hardware specs running the same firmware and release. Am I missing something? Here is the info… Router #1 interfaces-> Add->OVPN client has UDP as an option and router #2 does not.
Router #1
RouterBOARD
Model RB750Gr3
Revision r4
Serial Number xxxxxxxx
Firmware Type mt7621L
Factory Firmware 6.48
Current Firmware 6.48
Upgrade Firmware 7.12.1
Uptime 39d 17:09:12
Free Memory 193.1 MiB
Total Memory 256.0 MiB
CPU MIPS 1004Kc V2.15
CPU Count 4
CPU Frequency 880 MHz
CPU Load 1 %
Free HDD Space 3976 KiB
Total HDD Size 16.0 MiB
Sector Writes Since Reboot 881 144
Total Sector Writes 2 624 581
Architecture Name mmips
Board Name hEX
Version 7.12.1 (stable)
Build Time Nov/17/2023 11:38:45
Factory Software 6.46.3
Router #2
RouterBOARD
Model RB750Gr3
Revision r4
Serial Number xxxxxxxxxx
Factory Firmware 6.47.9
Current Firmware 6.47.9
Uptime 01:21:26
Free Memory 208.4 MiB
CPU Count 4
CPU Load 0 %
Free HDD Space 4156 KiB
Board Name hEX
