Hi
I try to set up an OVPN connection on RouterOS but the connection fails all the time
it has been 48 hours I’m working on it and seems unsolvable to me!
I tried OVPN client on windows, and OVPN client on another RouterOS, and it’s unsuccessful on both.
I tried every possible way that came to my mind.
- creating multiple certificates
- checking and unchecking options on server config
- changing client config file
- trying different versions of OVPN client software on windows
- and so on..
but as I said, even Mikrotik router as client can’t connect to server. so the problem isn’t about client software and windows config file. it seems something more general
My server config:
/interface ovpn-server server
set certificate=server-template cipher=blowfish128,aes128,aes192,aes256 \
default-profile=vpn enabled=yes port=80 require-client-certificate=yes
Server log:
19:00:23 ovpn,info TCP connection established from Y.Y.Y.Y
19:00:23 ovpn,info OVPN: TCP connection established from Y.Y.Y.Y
19:00:23 ovpn,debug,packet OVPN: sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=4ac49dba6da5ea6e pid=0 DATA len=0
19:00:42 ovpn,debug OVPN: <Y.Y.Y.Y>: disconnected <could not negotiate TLS in time>
OVPN client config file on windows:
client
dev tun
proto tcp-client
remote X.X.X.X
port 80
nobind
persist-key
persist-tun
tls-client
remote-cert-tls server
ca ca-template.crt
cert client-template.crt
key client-template.key
verb 4
mute 10
cipher AES-256-CBC
auth SHA1
auth-user-pass secret.txt
auth-nocache
;redirect-gateway def1
OVPN client log on windows:
Tue Dec 31 18:53:13 2019 Restart pause, 10 second(s)
Tue Dec 31 18:53:23 2019 Re-using SSL/TLS context
Tue Dec 31 18:53:23 2019 Control Channel MTU parms [ L:1623 D:1210 EF:40 EB:0 ET:0 EL:3 ]
Tue Dec 31 18:53:23 2019 Data Channel MTU parms [ L:1623 D:1450 EF:123 EB:406 ET:0 EL:3 ]
Tue Dec 31 18:53:23 2019 Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1559,tun-mtu 1500,proto TCPv4_CLIENT,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-client'
Tue Dec 31 18:53:23 2019 Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1559,tun-mtu 1500,proto TCPv4_SERVER,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-server'
Tue Dec 31 18:53:23 2019 TCP/UDP: Preserving recently used remote address: [AF_INET]X.X.X.X:80
Tue Dec 31 18:53:23 2019 Socket Buffers: R=[65536->65536] S=[65536->65536]
Tue Dec 31 18:53:23 2019 Attempting to establish TCP connection with [AF_INET]X.X.X.X:80 [nonblock]
Tue Dec 31 18:53:23 2019 MANAGEMENT: >STATE:1577805803,TCP_CONNECT,,,,,,
Tue Dec 31 18:53:24 2019 TCP connection established with [AF_INET]X.X.X.X:80
Tue Dec 31 18:53:24 2019 TCP_CLIENT link local: (not bound)
Tue Dec 31 18:53:24 2019 TCP_CLIENT link remote: [AF_INET]X.X.X.X:80
Tue Dec 31 18:53:24 2019 MANAGEMENT: >STATE:1577805804,WAIT,,,,,,
Tue Dec 31 18:53:24 2019 MANAGEMENT: >STATE:1577805804,AUTH,,,,,,
Tue Dec 31 18:53:24 2019 TLS: Initial packet from [AF_INET]X.X.X.X:80, sid=44310810 c1ebc1ca
Tue Dec 31 18:53:50 2019 read TCP_CLIENT: Unknown error (code=10060)
Tue Dec 31 18:53:50 2019 Connection reset, restarting [-1]
Tue Dec 31 18:53:50 2019 TCP/UDP: Closing socket
Tue Dec 31 18:53:50 2019 SIGUSR1[soft,connection-reset] received, process restarting
Tue Dec 31 18:53:50 2019 MANAGEMENT: >STATE:1577805830,RECONNECTING,connection-reset,,,,,
And I should say I read other topics related to this problem, but none of theme were helpful.
