OVPN Connections Dropping Constantly
Hi All
I have quite a few OVPN connections coming into my main core router which get settled on their respective bridges. Since a few days ago, 2 of these connections have started this pattern where they would connect for a few seconds (10 seconds) and then disconnect and would then struggle to reconnect for a while (30+ seconds). I don’t recall anything changing recently and the only difference between these 2 connections and the others are that these do not connect via the WAN but through an existing bridge (so in essence I’m piggybacking on another network/bridge to get to the router to establish a VPN link to another portion of the network/bridge).
I’ve enabled logging but it’s not showing much … “peer disconnected”, then a few “connecting”, “could not connect” and then eventually it will reconnect again. I’ve also run ping tests which are fine/constant and I can even connect to the router via the “guest bridge” and monitor these connection attempts.
Any ideas?
Thanks,
R
